that_corey_guy
Apr 15, 2021Initiate
Orbi RBK852 WiFi - SSID Not Visible on Clare One and Older PC
Firmware Version: V3.2.18.1_1.4.14 I recently purchased the Orbi Whole Home Tri-band Mesh WiFi 6 System (RBK852) – Router with 1 Satellite Extender. Everything seems to be working fine with most...
that_corey_guy
Apr 16, 2021Initiate
Yeah, it was working with the Eero router that came with the house. It looks like it’s on the 5Ghz frequency from the settings that I can see. The Clare One was setup by the tech guys when they installed everything.
I’ll just check back with them. They may have to do something behind the scenes as there is another installer menu on that Clare One panel that I don’t have the PIN to access.
vajim
Apr 16, 2021Master
need to find out if it's looking for 5g ONLY
