maxpuissant
Sep 19, 2025Guide
Orbi RBR350 + 2 satellites internet speed question
Hi! I use a RBR350 Orbi connected to 2 RBS350 satellites in my house with 2 floors. There is a big concrete wall in the middle of the house. So basically, the router and the RBR350 are downstairs, ...
maxpuissant
Sep 24, 2025Guide
Hi!
Do you think I should go with a "high end" powerline, meaning 2000 Mb/s or a 1000 Mb/s will be enough? I have a 500 Mb/s ISP speed.
Thanks!
Sep 24, 2025Guru - Experienced User
maxpuissant wrote:Do you think I should go with a "high end" powerline, meaning 2000 Mb/s or a 1000 Mb/s will be enough? I have a 500 Mb/s ISP speed.
Get AV2 (2000 mbps). The 2000 spec is the link speed, not the delivered throughput (which is MUCH lower).
