maxpuissant
Sep 19, 2025Guide
Orbi RBR350 + 2 satellites internet speed question
Hi! I use a RBR350 Orbi connected to 2 RBS350 satellites in my house with 2 floors. There is a big concrete wall in the middle of the house. So basically, the router and the RBR350 are downstairs, ...
Sep 24, 2025Guru - Experienced User
Either should work. Since the 350 series is only 1Gb, will only use that speed.
maxpuissant wrote:Hi!
Do you think I should go with a "high end" powerline, meaning 2000 Mb/s or a 1000 Mb/s will be enough? I have a 500 Mb/s ISP speed.
Thanks!
FURRYe38 wrote:Either should work. Since the 350 series is only 1Gb, will only use that speed.
The conversion rate is only 30-35%, so a 1000 mbps system only delivers 350 mbps speeds. Like Wifi, that is half-duplex. See
- https://www.tp-link.com/us/support/faq/2928/
And the 350 mbps is the best case, it often delivers much less. See for instance this post: NH RS300 - QoS | NETGEAR Communities Looking at powerline to solve a similar connectivity problem, and found even AV2 didn't work at all.
If maxpuissant is aiming for 500 mbps he should get the AV2 ("2000" mbps).
If the rooms have Coax wiring for TV, then MoCa is another option.
