ROLgear
Jul 21, 2022Aspirant
Orbi RBR350 wired connections and internet constantly dying
Since the last 2-3 weeks my Orbi RBR350 keeps going down. Purple light off and on, Virgin Media tests showing all is fine. Reboot of Virgin Hub 3 then Orbi solves it. But my wired satellite doesn't...
Aug 26, 2022Guru - Experienced User
I would not recommend using USB hubs like that for USB to ethernet connections.
These work however:
https://www.amazon.co.uk/Ethernet-Adapter-Thunderbolt-Gigabit-Compatible/dp/B07XTGKP5M/ref=sr_1_3
ROLgear
Aug 28, 2022Aspirant
Thanks, yes I have one of those as well. The hub seemed a like a good idea to avoid too many cables but looks like I was wrong.
