brianguy
Nov 02, 2020Star
Orbi RBR750 - webpages and iPhone Apps don't load
I've been reading through several posts in this forum around this same issue, and have not had any luck fixing our at home network. We have the Orbi RBR750, and have the Netgear Nighthawk CM1100 D...
Nov 02, 2020Guru - Experienced User
Ok, If you updated thru the Orbi app, at somepoint you might try to reload FW using a wired PC and web browser thru the RBRs web page.
IF you have lots of wifi neighbors near by, you can try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings. This helps with reducing the over all wifi foot print and interferience of that foot print with nieghboring wifi signals...
Armor is seen on the Orbi app and presented as a option to enabled when first option after doing a reset on the RBR and walking thru the setup wizard...
brianguy
Nov 02, 2020Star
I will add those two suggestions to my list of items to investigate tonight.
As for Armor, yes it does appear to be activated.
- FURRYe38Nov 02, 2020Guru - Experienced User
Ok, Seen odd problems steming from the use of Armor. Try this, disable Armor in the app. Once the app reports it disabled. Power cycle the RBR then test for these problems. If your still seeing problems, I recommend a factory reset of the RBR and setup from scratch, this time do NOT enable Armor.
