brianguy
Nov 02, 2020Star
Orbi RBR750 - webpages and iPhone Apps don't load
I've been reading through several posts in this forum around this same issue, and have not had any luck fixing our at home network. We have the Orbi RBR750, and have the Netgear Nighthawk CM1100 D...
Nov 02, 2020Guru - Experienced User
Have you turned OFF the RBS and just use the RBR alone?
brianguy
Nov 02, 2020Star
I will try turning off the RBS next.
I did however test this point below, and it did not seem to work.
> Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
- FURRYe38Nov 02, 2020Guru - Experienced User
:smileywink:
- brianguyNov 03, 2020Star
Update from my end..
Currently I have Armor disabled, and I changed the CTS values to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings. All other settings I have reverted.
The two issues described above with Apps & webpages loading on the iPhone and the issues with windows laptop connection issue didnt seem as to trigger as much or at all. I'm going to keep this setting in place for today and continue to monitor.
- FURRYe38Nov 03, 2020Guru - Experienced User
Ok, let us now how it goes...
- brianguyNov 04, 2020Star
Over the last couple of days, the two issues have decreased by about 75%, which is great. I feel like some of the steps done did actually help. Any other suggestions to perfect this issue?
- FURRYe38Nov 04, 2020Guru - Experienced User
Turn OFF all RBS and test these two problems with just the RBR running alone...same thing still happen?
Then turn on 1 RBS and test again...
- brianguyNov 04, 2020StarOk just tried disconnecting the satellites and that didn’t seem to help. Initial sense was that it actually make it worse.
Is the RBR power out put levels at 100% or lower?
You might try to reload FW using a wired PC and web browser thru the RBRs web page. Factory reset and setup from scratch.
If this still doesn't seem to help any, I would open up a support ticket with NG and check on an RMA...
- brianguyNov 06, 2020Star
Yes, they are both 100%.
I will attempt the hard resent along with the hardwire install of the FM this weekend.
