Retired_Member
Sep 22, 2024Re: Orbi RBR750 with RBS350 satellites
The only way I managed to connect the RBR750 to RBS350 is by downgrading the firmware to V4.6.14.3. I was using originally using V7.2.6.31 on the RBR750. After I downgraded the firmware, and connected the two devices, interestingly the RBS350 was also downgraded from V4.4.1.29 to V4.6.14.3. It works ok, but I miss the RBR750's IoT function so wondering if anyone was able to use the latest firmware and manage to connect both devices?
1 Reply
v7 FW is not compatible with RBS350s. So if you have those connected, to ensure they work with the RBR750, you have to keep v4 FW loaded on the RBR750. Or find you some used RBS750s to swap in for the 350s.
