say_xtr
Feb 05, 2025Aspirant
Re: Orbi RBS 850 Satellite with RBR 960
Hi All After reading this topic I quickly browse for used 850 satellite and I get myself lucky when I found 1 unit under $15 in my local market. The existing system running in my house is the 960...
Feb 06, 2025Guru - Experienced User
FYI:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
What FW version is on the existing system and the incoming RBS? You'll need to make sure that FW version is same between the two.
- say_xtrFeb 09, 2025AspirantOnly can detect the 960 router firmware. Can’t find any details on the 850 satellite firmware. Any idea?
- FURRYe38Feb 09, 2025Guru - Experienced User
Try this with the RBS850:
- say_xtrApr 30, 2025Aspirant
Hi
Sorry for late reply.
I refer the PDF file from the link provided but stuck at page 3 item no 8 which nothing pop up at the browser after I navigate to 192.168.10.250
I'm sure I did everything exactly what the instruction asking me to do from page 1 but failed.
Any suggestion please?
