say_xtr
Feb 05, 2025Aspirant
Re: Orbi RBS 850 Satellite with RBR 960
Hi All After reading this topic I quickly browse for used 850 satellite and I get myself lucky when I found 1 unit under $15 in my local market. The existing system running in my house is the 960...
say_xtr
Feb 09, 2025Aspirant
Only can detect the 960 router firmware. Can’t find any details on the 850 satellite firmware. Any idea?
Feb 09, 2025Guru - Experienced User
Try this with the RBS850:
- say_xtrApr 30, 2025Aspirant
Hi
Sorry for late reply.
I refer the PDF file from the link provided but stuck at page 3 item no 8 which nothing pop up at the browser after I navigate to 192.168.10.250
I'm sure I did everything exactly what the instruction asking me to do from page 1 but failed.
Any suggestion please?
- FURRYe38Apr 30, 2025Guru - Experienced User
Hmmm. Possible FW on the 850 could be older. Can try 192.168.1.250? You'll need to set same subnet on PC for the static IP address to try this.
What happens if you ethernet connect the RBS to the back of the RBR and give say 5 minutes, does it appear on the RBRs web page with a IP address? If it does, can you access the web page using that IP address?
- say_xtrMay 09, 2025Aspirant
Haven't try 192.168.1.250 yet
but... when I plug in behind RBR960 with ethernet, this pop up (refer picture, item no 4 in line)
