Deepak_Mehta
Aug 18, 2022Aspirant
Orbi Satellite RBR850 doesnt connect
I facing a big problem, i have installed 1 Orbi router and 5 satellite RBR850 in an 3 storey house, and placed the devices floor wise ( some in rooms couple of them in bedroom and living rooms) at sp...
Aug 18, 2022Guru - Experienced User
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
So you have RBS that are wireless connected and some wire connected?
Are the ethernet connected RBS directly connected to the RBR or is there a patch panel or LAN switch in between the RBR and RBS? If there is a switch, brand and model# please.
What CAT# lan cable are you using? CAT6 is recommended.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What CTS values are you using on the RBR? Under Advanced Tab/Advanced Settings/Wireless Settings
You may also have too much wifi signal in the home. 1 RBR and two RBS are rated up to 7500sq ft so 3 RBS should be enough for 8000sq ft. I would turn off two of the RBS and test the system and devices. https://youtu.be/UR0viMLISz4
Deepak_Mehta
I have changed power output to 50%
So you have RBS that are wireless connected and some wire connected? Yes
Ethernet are connected RBS via Cisco unmanged switch which is between the RBR and RBS?
Yes i am using CAT6
I am using 48 on 5Ghz. and 6 on 2.4Ghz.
There are 2-3 wifi neigbhors with very very weak signal
CTS values is kept on automatic
Will try to keep off couple of devices.
Sharing a snapshot of devices.
- FURRYe38Aug 19, 2022Guru - Experienced User
Ethernet are connected RBS via Cisco unmanged switch which is between the RBR and RBS? <What is the model# of this switch?
Yes i am using CAT6
CTS values is kept on automatic <CTS values should read a number and not automatic
- Deepak_MehtaAug 19, 2022Aspirant
CTS / RTS Threshold :- 64
- Deepak_MehtaAug 20, 2022Aspirant
As details were discussed in above post i have done all the settings as you told me, still same issue is there,
Devices gets disconnect and reconnect after sometimes and this happens all the time.
Is there any other solution to find out and rectify this issue.
Frequently RBS are changing their connection with RBR.
- FURRYe38Aug 20, 2022Guru - Experienced User
You might update FW on the system.:
Update the RBS first then RBR lastly. Use a wired PC and web browser to send the FW file to the RBS web page, then update the RBR lastly. After the RBR and RBS are back online. Try a full power OFF of the ISP modem, RBR and RBS for 1 minute or longer then back ON with the ISP modem first, RBR then RBS lastly. If the one RBS continues, you may want to try a full on factory reset of the RBR and RBS and setup from scratch.
