Deepak_Mehta
Aug 18, 2022Aspirant
Orbi Satellite RBR850 doesnt connect
I facing a big problem, i have installed 1 Orbi router and 5 satellite RBR850 in an 3 storey house, and placed the devices floor wise ( some in rooms couple of them in bedroom and living rooms) at sp...
Aug 19, 2022Guru - Experienced User
Deepak_Mehta wrote:
I have changed power output to 50%
So you have RBS that are wireless connected and some wire connected? Yes
Ethernet are connected RBS via Cisco unmanged switch which is between the RBR and RBS? <What is the model# of this switch?
Yes i am using CAT6
I am using 48 on 5Ghz. and 6 on 2.4Ghz.
There are 2-3 wifi neigbhors with very very weak signal
CTS values is kept on automatic <CTS values should read a number and not automatic
Will try to keep off couple of devices.
Sharing a snapshot of devices.
Deepak_Mehta
Aug 20, 2022Aspirant
CTS / RTS Threshold :- 64
