Tcrus
May 03, 2020Luminary
ORBI showing connected but no WIFI, Modem going offline occasionally
Equipment: ORBI RBR850 and a CM1000 I am having WIFI connection issues. My WIFI will be great then it will drop a few times and completely go out. It shows me as connected to WIFI but there is no co...
May 04, 2020Guru - Experienced User
Ok, that mabye to far in distance. See how it goes. If you notice problems with the RBS, move the RBS closer to the RBR.
Tcrus
May 06, 2020Luminary
Well it seems my problem has stopped so changing out my modem maybe fixed it (2-3 days of a solid connection), would like to test old modem to and see if that was really the problem and not my ISP but its working so not gonna fool with it. Thanks for all the help and suggestions
- FURRYe38May 06, 2020Guru - Experienced User
Good to hear. Please mark your thread as solved.
Enjoy. :smileywink:
