wheaties82
Mar 22, 2022Aspirant
Re: Orbi speed issue
I have a similar issue. I have full 1GB fiber internet (up + down) from my ISP. When I initially reboot ORBI RBR850 and do hard wire speed tests (ookla) I see ~850Mbps download and ~860 Mbps upload...
Mar 22, 2022Guru - Experienced User
How are the RBS connected to the RBR using ethernet? Directly to the back or is there a LAN switch or wall jacks in between them?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
