Baywatch
May 12, 2022Guide
Orbi Tri-band Mesh WiFi 6 Router
Hi ... I have a n Orbi Tri-band Mesh WiFi 6 Router plus 3 satellites ... everything was and in working perfectly ... but now I cannot login to the Router ... I can't get to via local browser. I can l...
May 12, 2022Guru - Experienced User
Factory reset and setup from scratch using a wired PC and web browser at HTTP 192.168.1.1. Don't use Orbi app.
Baywatch
May 12, 2022Guide
That's the solution ... start over for no reason?
- FURRYe38May 12, 2022Guru - Experienced User
We have no idea IF or when NG will be fixing this or how they will push it out. For immediate resolution, a factory reset is needed. Otherwise you can wait for NG to do something or make contact with NG support:
https://my.netgear.com/support/contact.aspx
Others have already posted that factory resets resolves this.
- BaywatchMay 23, 2022Guide
Thanks ... I will do the reset ... but I can't say I'm happy about have to re-do address assignments, port forwarding, etc. Would be nice to have an explanation about I can't reach my Router on my LNA LOL.
- FURRYe38May 23, 2022Guru - Experienced User
You and everone else.
I highly recommend after you reset and setup again, that you make a backup configuration to file. Saves time should any factory reset be needed in the future: https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-System
