May 13, 2022Guru - Experienced User
Orbi Web Page and Orbi app Access Status
ALL USERs: NG is aware and is working on fixing the problem currently with users having problems accessing the system using Orbi app and web page with a browser. Please be patient.
In mean time...
FYI:
If you downgrade, the Orbis will not re-update to anything newer. New FW versions have been removed.
I recommend that after you downgrade the RBS first then RBR lastly, power OFF all units for 1 minute then back ON. Use a wired PC and web browser for this.
If you experience any problems, A factory reset will be needed and setup from scratch.
May 16, 2022Guru - Experienced User
FYI,
"We have a fix that we are slowly deploying to a small group of users and working toward a large-scale deployment as soon as possible but could be longer than 48 hours."
