KRYPTONITE
May 28, 2020Aspirant
ORBI WIFI 6 AX6000
I WANT TO SETUP 8 OF THESE. CAN I ADD 7 SATELLITE TO A SINGLE NETWORK SYSTEM. IF SO, I WANT TO SETUP 4 OF THOSE THROUGH ETHERNET BACK HAUL AND 4 OF THOSE WITH WIRELESS BACKHAUL. WHAT ARE MY OPTIONS?
May 28, 2020Guru - Experienced User
You may want to just run ethernet or power line adapters if needed and setup all RBS wired. Concrete and steel will always have an impact on any wifi system. AX or otherwise.
kildare
May 28, 2020Luminary
I'm not sure you can add up to 7 satellites to the current Orbi AX6000 implementation.
Even the business system Orbi Pro AC3000 can have up to 6 satellites:
Larger space? No problem. Orbi Pro’s got it covered
Extend your WiFi range further than before. Add up to 6 satellites to the Orbi Pro Router.
https://www.netgear.com/orbi-pro/default.aspx
Better check with the Netgear support.
