paras_waiba
Jun 29, 2024Follower
Re: Orbi WiFi 6 (RBR850) Backhaul Status Out of Sync w/ Satellite (RBS750)
RBS Satellite 'out-of-sync" problems I got this resolved just by going to Advanced tab and under "Firmware update" then choose "Manual update" choose the RBS750 Satellites and do the latest FW update and then my out-of-sync issues was resolved.
No need to reset to factory settings as some have suggested.
In case nothing works then I would recommend factory reset and doing FW updates.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
1 Reply
Enjoy. 📡
