steve37066
Apr 27, 2022Tutor
ORBI350 continuely resynching
ORBI350 with 1 satellite, both on firmware v4.4.0.10_2.10.63. Router is in APmode. Recently I find the satellite is very often in synchronising mode. That is to say that the white LED starts flashi...
- Apr 28, 2022
I'd try 1-6-11.
Not sure what you're options are for 5ghz and I don't have a dual band version to test with
Apr 28, 2022Guru - Experienced User
I'd try 1-6-11.
steve37066
Apr 29, 2022Tutor
OK setting channel 1 seems to have resolved the issue.
Many thanks for your help
Steve
- plemansApr 29, 2022Guru - Experienced User
Glad it was a simple fix!
If it happens again, try a different channel. More than likely an interference issue and the 350 series doesn't have the dedicated backhaul so they're a little more sensitive.
A backup is always a good idea.
