VYG
Jul 22, 2021Aspirant
Packet loss for wired device on RBK352
Hi all any suggestion oin this one : Orbi's are connected via wired backhaul. Synology NAS is connected to a main one. When I ping the main one there is no packet loss, whilst doing this I ping the ...
Jul 22, 2021Guru - Experienced User
VYG wrote:So if you connect yoru PC at the RBR and ping the NAS, any packet loss? If I connect the PC to RBR or RBS directly via cable no issue is observed.
What CAT version of LAN cables are the RBS and NAS using that connects them the RBR? CAT5, CAT6 were tested.
So no PL issues seen via wired connection. You do see pack loss when connected wirelessly?
Can that be that RBR which is a gateway was experiencing some issues with perfromance at that time? But NAS is connected direclty to NAS via cable so it should not affect anything related to radio??
VYG
So no PL issues seen via wired connection. You do see pack loss when connected wirelessly?. Yes, the issue is observed only if I am conncted wirelessly to RBS.
What is the size of your home? Sq Ft? The flat is 75 sq. F
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected. The distance beween RBS and RBR is 32 feets.But! RBR and RBS are backhaulved via wired connection, so there must not be any packet loss between RBS and RBR. So the guess is:
- either RBS and RBR are still talking to each other via wireless backhaul
- or there is something beween this chain - PC>RBR>RBS - and it should be RBR then......
