MrcleanMC
Aug 13, 2024Aspirant
Re: Possible Fix for iPhone Dropping WiFi
Hi all, Just a quick note in case NG reads this that I've been struggling with the same issue for several months with the 960 and it has been driving me absolutely nuts. I'm glad I found this t...
MrcleanMC
Aug 15, 2024Aspirant
I was thinking I used a netgear switch, but upon inspection it is not.
This is the switch I have: TRENDnet TEG-S350.
TRENDnet 5-Port Unmanaged 2.5G Gaming Switch, 5 x 2.5GBASE-T Ports, 25Gbps Switching Capacity, Backwards Compatible with 1000Mbps Devices, Fanless, Wall Mountable, Lifetime Protection, Black,TEG-S350
Aug 15, 2024Guru - Experienced User
Ok, I'd start by the following,
Downgrading the RBS first then RBR lastly to v.21 and then factory reset and setup from scratch:
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Ensure you don't use the separate 6Ghz SSID network.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Might try this for Apple phone or pads with cell phone features:
On your iPhone, go to Settings>Cellular. Scroll ALL the way down, past all the toggles for individual apps. Just past the apps section is a toggle for "WiFi Assist". This allows the iPhone to "automatically use cellular data when Wi-Fi connectivity is poor". Toggle this to OFF.
Any newer generation phones that support 6Ghz, see about disabling 6Ghz and testing with out this enabled...
- MrcleanMCAug 15, 2024Aspirant
Thank you. I will try the firmware downgrades. I already disabled wifi 6 and also turned off wifi assist. Didn't seem to help. It seems to only be an issue with my iphone 15 pro.
- FURRYe38Aug 15, 2024Guru - Experienced User
Others are noticing issues withe the newer generation tri band iPhones and latest versions of iOS. 🙄
