MrcleanMC
Aug 13, 2024Aspirant
Re: Possible Fix for iPhone Dropping WiFi
Hi all, Just a quick note in case NG reads this that I've been struggling with the same issue for several months with the 960 and it has been driving me absolutely nuts. I'm glad I found this t...
MrcleanMC
Aug 15, 2024Aspirant
Thank you. I will try the firmware downgrades. I already disabled wifi 6 and also turned off wifi assist. Didn't seem to help. It seems to only be an issue with my iphone 15 pro.
Aug 15, 2024Guru - Experienced User
Others are noticing issues withe the newer generation tri band iPhones and latest versions of iOS. 🙄
