choefler
Aug 19, 2024Apprentice
Re: Possible Fix for iPhone Dropping WiFi
i tried this but the problem is still there..
choefler
Aug 14, 2024Apprentice
Europa
v7.2.6.31
all over Ethernet connected
is all off
v7.2.6.31
is all off
Aug 19, 2024Guru - Experienced User
Since your in the EU region, you might try v6 FW since v.21 wasn't supported in the EU region. If you do, RBS first, then RBR lastly, then factory reset and setup from scratch.
choefler wrote:
Europa
v7.2.6.31
is all off
- choeflerAug 19, 2024Apprentice
i also tried 6.3.7.10 same problem..
- FURRYe38Aug 19, 2024Guru - Experienced User
Sounds like you'll need to wait for Apple and NG to get this fixed then. Open a support ticket with both Mfrs if you haven't already. Seems like were seeing more issues since newer iOS version appeared and on tri band model iPhones. I don't have a tri band iPhone so I don't see this issue here.
i allready have opened a Case by Netgear: Casenumber: 48267039
since 2 month there is no Solution by Netgear..
Apple has closed my case because they said its a problem by Netgear..
