choefler
Aug 19, 2024Apprentice
Re: Possible Fix for iPhone Dropping WiFi
i tried this but the problem is still there..
Aug 19, 2024Guru - Experienced User
Since your in the EU region, you might try v6 FW since v.21 wasn't supported in the EU region. If you do, RBS first, then RBR lastly, then factory reset and setup from scratch.
choefler wrote:
Europa
v7.2.6.31
all over Ethernet connected
is all off
choefler
i also tried 6.3.7.10 same problem..
- FURRYe38Aug 19, 2024Guru - Experienced User
Sounds like you'll need to wait for Apple and NG to get this fixed then. Open a support ticket with both Mfrs if you haven't already. Seems like were seeing more issues since newer iOS version appeared and on tri band model iPhones. I don't have a tri band iPhone so I don't see this issue here.
