RonBZ
Jun 20, 2024Follower
Re: Possible solution for Orbi dropping connection (when connected to satellite)
Yes it was turning off Access Control that stopped my RBS350 from constantly reconnecting. After 2 years same fault still exists.
Jun 24, 2024Guru - Experienced User
What Firmware version is currently loaded on the RBS?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What model RBR is the RBS350's connected too?
