Nnyan
Oct 13, 2022Tutor
RBK753 firmware update
So I noticed that there was an upgrade to my RBK753. I went into the IP address for the router and it only showed an upgrade for the RBR750 and not the two satellites (V4.6.9.11). I went ahead and ...
ekhalil
Oct 13, 2022Master
Please login directly on the satellites using their IP addresses (check which addresses are assigned to the satellites in the router) and do a manual upgrade. Downlaod the firmware from the Netgear Support page.
