orbira's avatar
orbira
Apprentice
Sep 01, 2020
RBK753 Port forwarding not working from LAN hosts
Hi,   I just installed Orbi RBK753 in router mode. There is no router in front of it and the netgear router is directly connected to WAN. I have setup port forwarding to forward https (port 443) to...
  • pickwit's avatar
    pickwit
    Sep 06, 2020
    Hi Orbira,
    I have had no issues with port forwarding at all before and after the hot-fix. The hot-fix firmware which is for the router only has definitely resolved my NAT loopback issue with the RBK852 satellite.
    I have DM'ed you with my case number.
    Good luck!
