phusebox
Jun 30, 2020Guide
RBK852 Nat loopback bug on satellite
I have a domainname setup to access the NAS on my network. For example mydomain.com When I go to this domain on an external network, so out of home or on my phone provider, everything works fine. ...
phusebox
Jul 01, 2020Guide
Well, the funny thing is it does work when the satellite is not connected to a cable backhaul or when the client is connected to the router.
gb777
Jul 01, 2020Apprentice
"connected to the router" with an Ethernet cable without a switch in between, or connected via wireless? Make sure you have the wireless turned off.
Those are different interfaces inside the devices. I tested on mine running "nc" directly on the router (so coming from 127.0.0.1) and it didn't work. Inside the router, there are multiple interfaces from which packets can be received. Wired and wireless use different interfaces. The port forwarding rules must accommodate both.
The router generally can't tell if there's a switch between its wired interface and the client or not. All Layer 2 protocols are designed to be transparent in this respect, especially with unmanaged switches, which are simple frame forwarders (plus some learning of the topology of your home network). Not that it's impossible for the switch to play a role, but just very, very unlikely.
- phuseboxJul 01, 2020GuideWill try again just with Ethernet and without WiFi.
