Kevin923846
Sep 22, 2021Star
RBK852 useless after latest firmware update!
Did anyone else experience a complete nightmare with the latest firmware (4.6.3.16_2.0.51) on the RBK852 / RBK853? It completely crashed my whole system. First the satellites disapeared. Then I d...
Sep 22, 2021Guru - Experienced User
I recommend you block NGs autoupdate services on your host router then downgrade back to v3:
http.fw.updates1.netgear.com
Kevin923846
Sep 22, 2021Star
I would love to but from everything I read, this is not possible. Also, I am on a Mac not Windows.
- FURRYe38Sep 22, 2021Guru - Experienced User
Can you load up FireFox or Opera on your Mac?
It's possible...I tried this last night however not on my Mac...Mac FireFox or Opera should work...
- Kevin923846Sep 22, 2021Star
I'll give it a try. Thanks.
đ
- FURRYe38Sep 23, 2021Guru - Experienced User
Were you able to do this?
- Kevin923846Sep 25, 2021Star
So some updates and findings. I have not attempted to rollback the firmware but may give it a go this weekend while internet access is not as critical for business.
Here is what I have found:
- The satellite is discoverable only with a wireless backhaul. Once the satellite plugged into the main Orbi router it ceases to function.
- The satellite is discoverable in Router mode during setup, but not in AP mode.
- The entire system is flaky now. After 2 full resets and building the network again the latest firmware update has left the system much less reliable than it was previously.
Why does Netgear continue to ignore this situation? It seems to be directly related to the problems many other are reporting with the RBK752 / RBK753 firmware.
