TeddyOH
Oct 20, 2020Guide
RBK853 Ethernet Backhaul Causing Wifi to Drop
Orbi RBR850 in office connected to the modem. RBS850 in kitchen connected wireless to the router. RBS850 in basement connected via an unmanaged switch that has an ethernet connection directly from ...
Oct 20, 2020Guru - Experienced User
What Firmware version is currently loaded? All units on same version of FW?
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch in the configuration?
Are both RBS connected to the switch?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
TeddyOH
Oct 21, 2020Guide
To answer questions posted:
1) Firmware is stated in OP. I reflashed the router yesterday and confirmed both sats are same version.
2) Modem is provided by Spectrum/Charter and is their own brand. It was required for their Gig service. Sorry I am not home to give model number, but again the modem is confirmed to be functioning nominally.
3) Router mode
4) Ethernet switch is an unmanaged Netgear 16 port gigabit switch I just purchased this week. GS116NA. Only 1 sat is connected to the switch. I have not tried running the Ethernet from the router to the sat and then from the sat to the switch. Not sure if that would matter.
5) Not an oversat issue. The wired sat is in the basement over 30 ft away. The wifi sat is in the kitchen 3 rooms away, over 30 ft.
As an update, I called tech support. They had me reinstall the same firmware to the router only. Then they had me change the MTU router setting from the default 1500 to 1472. They said test it. Failure once again. Lost internet via wifi within 10 min of reconnecting the Ethernet backhaul. Once again, anything connected wired via Ethernet still had full internet access.
They asked me to call back if it didn’t work, but I’m not sure I will. They are obviously just working a nonspecific troubleshooting algorithm and have no clue about a solution.
3) Router mode
- FURRYe38Oct 21, 2020Guru - Experienced User
Try directly connecting both RBS to the switch, then try removing the switch from the mix and directly connect both RBS to the back of the RBR.
What version# is the switch? v1, etc...
- TeddyOHOct 21, 2020GuideOk. Problem solved, but the solution created another problem...
I rewired the connections. Now I have direct Ethernet from the RBR850 to the basement RBS850 setting up Ethernet backhaul. Then Ethernet from that RBS850 to my switch connecting all my basement home theater devices.
So essentially changing the order of connection solved the problem. Stable network with Ethernet backhaul enabled on the basement sat.
HOWEVER...
Now, all the basement devices with wired Ethernet to that switch can’t get speeds of over 75-90 Mbps. My phone connected to the same sat by wifi is getting about 700-800 Mbps. So the output from the sat is fine by wifi but very slow by internet. Note that when I had the Ethernet straight to the switch, all these devices were getting 700 or more Mbps. Same cables just different order of connection.
So now what?- FURRYe38Oct 22, 2020Guru - Experienced User
Remove that switch. Do wired connection get faster speeds directly connected to this RBS?
