TeddyOH
Oct 20, 2020Guide
RBK853 Ethernet Backhaul Causing Wifi to Drop
Orbi RBR850 in office connected to the modem. RBS850 in kitchen connected wireless to the router. RBS850 in basement connected via an unmanaged switch that has an ethernet connection directly from ...
Oct 21, 2020Guru - Experienced User
Try directly connecting both RBS to the switch, then try removing the switch from the mix and directly connect both RBS to the back of the RBR.
What version# is the switch? v1, etc...
TeddyOH
Oct 21, 2020Guide
Ok. Problem solved, but the solution created another problem...
I rewired the connections. Now I have direct Ethernet from the RBR850 to the basement RBS850 setting up Ethernet backhaul. Then Ethernet from that RBS850 to my switch connecting all my basement home theater devices.
So essentially changing the order of connection solved the problem. Stable network with Ethernet backhaul enabled on the basement sat.
HOWEVER...
Now, all the basement devices with wired Ethernet to that switch can’t get speeds of over 75-90 Mbps. My phone connected to the same sat by wifi is getting about 700-800 Mbps. So the output from the sat is fine by wifi but very slow by internet. Note that when I had the Ethernet straight to the switch, all these devices were getting 700 or more Mbps. Same cables just different order of connection.
So now what?
HOWEVER...
So now what?
- FURRYe38Oct 22, 2020Guru - Experienced User
Remove that switch. Do wired connection get faster speeds directly connected to this RBS?
