vakr78
Feb 22, 2022Aspirant
Re: RBK853, wired backhaul: one satellite loses connection to router and daisychains to other satell
I have an RBK853 mesh system (one RBR850 router and two RBS850 satellites). The satellites are connected via separate ethernet cables to the router (star topology, wired backhaul). I want the sat...
- Mar 02, 2022
I have an update on this matter for anyone who is interested.
I did a factory reset of both satellites.
Then I started them up and synced them to the router, one at a time, using the wired connection in their final/intended resting places 50 ft away from router in other rooms/other floors.
(When I initially bought the pack, not knowing any better and following the instructions or so I thought, I synced them wirelessly and at the same time, sitting next to the router on the same table.)
I have had stable wired backhaul star topology for five days now. No spontaneous daisy-chaining has occurred.
The Cisco VPN thing appears to have been a red herring.
Thank you for taking the time to give me your input, FURRYe38 Mikey94025
vakr78
Mar 02, 2022Aspirant
- FURRYe38Mar 02, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
