Dhinla's avatar
Dhinla
Guide
Apr 29, 2022
Re: RBR750 - Have Internet and can ping router, but web management not accessible
This is exactly the same problem I am having.
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? You might try a full on factory reset and setup from scratch using the Orbi app and walk thru a New Setup there.
    • asdf4137's avatar
      asdf4137
      I can't see what version is loaded because I can't access the device at all. It's whatever the firmware was as of an update a few weeks ago?
      It's not the modem or anything to do with my ISP. This is a problem with the Orbi management interface, whether via app or browser, being inaccessible. Yet I can access the Internet just fine and I can ping the Orbi via command line.
      This is a Netgear issue and clearly I'm not the only one having it. I DO NOT want to do a factory reset unless I absolutely have to.
