zrdcorp
Dec 18, 2021Tutor
RBR750 / RBS750 AP MODE NOT ACHIEVING STABLE WIRELESS BACKHAUL
I searched for a solution for this to no avail. I have tried all firmwares 4.6.3.7 and above. If i switch to AP mode they never get a stable wireless BACKHAUL. I have tried varying distan...
zrdcorp
Dec 20, 2021Tutor
Yeah. Laughing at Netgear is probably not the right response.
They should be sued, force to recall V4 firmware or all RBR750s, and replace them with something that works.
You are just describing another bug of V4 firmware and how it does not work correctly.
I have my setup identical on V3 and V4. In v4 it does not work, and in V3 it works.
That means my setup is wrong?
No.
That means V4 firmware is wrong.
Have you tried your setup on V3?
Rudolphy
Dec 20, 2021Apprentice
Sorry, had understood you so that you laugh at me!
Yes, I wanted to list another error of V4, although I can live with my settings with V4.
Under V3 everything ran smoothly, there was also no constant resync
- zrdcorpDec 20, 2021Tutor
The correct thing to do is have a sticky on THIS FORUM, that helps users to downgrade to V3.
It is far easier to downgrade to V3 than to try and live with the V4 bugs and problems.
