betamx
Dec 30, 2020Aspirant
RBR750: Firmware upgrade V3.2.16.22_1.4.9: IP Configuration Failure
Yesterday night I updated my router to the latest firware version "V3.2.16.22_1.4.9". After the update, most of my devices are failing to connect to the network with a message: "IP Configuration Fail...
- Dec 31, 2020
After reading a couple of forum posts, I tried to do an experiment: I reduced the DHCP range for the LAN and reserved IPs for some of the devices. With that done, after rebooting the router, these devices would connect reliabliy every single time. Right now, I seem to have about 40 odd devices & I reserved IPs for all of them. I've restarted my router a couple of times & even after that all devices seems to connect back. In fact, I left a few devices to use DHCP and they're working correctly as well.
I am wondering if there's a bug in the router's DHCP server module that fails to work if a lot of devices tries to connect to it at the same time requesting for IPs. This would be weird because we're talking about ~40 odd devices and not like ~1000s, causing some sort of a thundering herd problem. I'm not a network expert but this is my hunch so far.
Any other ideas or experiments would be appreciated.
FURRYe38 : Yes I tried to reset by pressing the reset button for over 15sec. In fact, I've done it multiple times since yesterday. But none of these steps have helped me so far
Mstrbig
Dec 31, 2020Master
betamx wrote:After reading a couple of forum posts, I tried to do an experiment: I reduced the DHCP range for the LAN and reserved IPs for some of the devices. With that done, after rebooting the router, these devices would connect reliabliy every single time. Right now, I seem to have about 40 odd devices & I reserved IPs for all of them. I've restarted my router a couple of times & even after that all devices seems to connect back. In fact, I left a few devices to use DHCP and they're working correctly as well.
After reserving IPs on your router, you must shut down and restart your devices. If you don't, they will retain the IP address they were initially given, until they expire, lose power or reboot. So, regarding your 40 odd devices, turn them off and restart them.
betamx
Dec 31, 2020Aspirant
Thanks for pointing it out. I did that today.
Appreciate all your help folks!
- FURRYe38Dec 31, 2020Guru - Experienced User
So was your problem fixed?
Appreciate all your help folks!- betamxDec 31, 2020Aspirant
Yes, for now, going with the static IPs seems to have worked. Not sure why though. I've not given your recommendation about playing with the different versions of the firmware a shot yet, FURRYe38
As long as you got it going and working. No need to play around with other versions.
Mark your thread and solved.
Enjoy. :smileywink:
