Mitch12345
Apr 01, 2022Follower
Re: RBR750 mesh system constantly dropping Wifi
I had the same issue, I had to leave the unit unplugged for a couple hours and then factory reset. Plugged them back in and set them up using the web based utility first. I have FiOS so my FiOS rou...
Apr 01, 2022Guru - Experienced User
Plugged them back in and set them up using the web based utility first. I have FiOS so my FiOS router uses 192.168.1.1, so the web base utility automatically changed my Orbi’s ip/access portal to 10.0.0.1 .
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Just an fyi. The Orbi iPhone app could not detect or set up my Internet settings, but for some reason the web based portal was able to detect and successfully set up Internet.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
For me the disconnecting wifi problem kept happening because I would plug in a ethernet backhaul cable to the satellite after initial set up which would then make everything wonky, causing it to constantly disconnect the Wi-Fi signal to all my devices. If you’re going to use an ethernet back hall, make sure that it’s plugged in from the start!
Its recommended to first set up the RBS and sync them wirelessly fully. Once fully since, then connect them via ethernet:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
Also be sure to use good quality LAN cable. CAT6 is recommended.
The entire set up is slow, with lots of waiting screens, extremely long load times for the hardware, and super tricky. Honestly it’s a huge pain for such an expensive system. They need to figure this out because it’s really terrible.
It's recommneded to use a wired PC and web browser to setup the system.
