helpmeplsdudes
Mar 31, 2025Aspirant
RBR750 Won't let some services like Netflix through
Hello, As of yesterday, my orbi which has worked great for 5 years suddenly won't allow certain services such as Netflix or my work VPN but works for other things such as browsing. Netflix & Max ...
- Apr 01, 2025
Thank you for the help, did a factory reset and it's back to normal, cheers 🙂
Mar 31, 2025Guru - Experienced User
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
KMDonlon
Mar 31, 2025Virtuoso
My IPv6 issue with v7.2.7.15 was causing similar problems like this... Have you tried going back to the prior firmware version to see if this fixes your issues?
- helpmeplsdudesMar 31, 2025Aspirant
yes I went back, no luck 😞
- FURRYe38Mar 31, 2025Guru - Experienced User
Possible something with the ISP maybe?
Does it work with out VPN?
but the VPN works when connected directly to the modem so wouldn't that indicate that the orbi is the problem?
