tigerisak
Mar 19, 2020Guide
RBR850 - Major issues with packet loss
Hi. Im having major issues with what I believe is packet loss. When trying to WFH now in Corona-times I discovered that my brand new Orbi isnt super stable when using - Aircall, Zoom or FaceTime. It ...
cengo
Mar 20, 2020Aspirant
You are right, the system was upgraded again last night.
I did already a factory reset before I downgraded the firmware version, but without success. Do you really think it could make sense now? Was it successful for you or is it only a suggestion?
DoctorA
Mar 20, 2020Luminary
Are you still experiencing problems? As of last night my problems are solved.
My I phone X Max and Gaming site disconnecting problems on wired PC desktop is solved since last night's automatic change.
I wish NG adds a simple click to stop further updates if people like me are happy with present configuration. Most electronic devices have that option. Are the other routers have the option? You can manually block the NG updating sites though.
