CPTLW
Sep 21, 2021Aspirant
RBR850 - White flashing light after firmware update to 4.6.3.16
Hi, I have an Orbi AX6000 RBR850 Router. It is not an option in the model list for some strange reason. (so i just selected a random model) After updating via the ios app, my main router now fla...
Sep 26, 2021Guru - Experienced User
Did you follow this?
https://community.netgear.com/t5/Orbi-WiFi-6/RBK750-Series-Firmware-Update-v4-6-3-7/m-p/2130584#M18586
https://community.netgear.com/t5/Orbi-AX/RBK750-Series-Firmware-Update-v4-6-3-7/m-p/2131307/highlight/true#M18670
CPTLW
Sep 27, 2021Aspirant
I read these - I didnt' get an answer regarding voiding warranty messing with things like telnet and entering the information. I don't even think its right to expect customers to know how to do this. I dont' feel comfortable doing it.
If I had known that netgear do not offer support for their products, even the most expensive ones in the shop I would not have bought.
It comes with a two year warranty which i'm 8 or so months into - so I'm contemplating just returning this and buying one that has support and has a UI that is easy to use. Anyway, now I know - don't purchase products that are not supported by their own company - it should be more clear on the box.
Not a recommended company or product for 95% of the population that don't work in IT.
- FURRYe38Sep 27, 2021Guru - Experienced User
May be your best option then...
