San_Tehnik
Jul 09, 2023Aspirant
Re: RBR850 can not connect to some websites over ethernet
Hey guys
I recently bought an RBR850 router and an RBS850 satellite I created a wired backhaul between them and connected all my devices. At first everything worked fine but then I decided to conn...
CrimpOn
Jul 09, 2023Guru - Experienced User
San_Tehnik wrote:
some sites do not work! Everything looks like my internet is down.
More detail, please. Is it correct to interpret this as:
- The problem is restricted only to some web sites, or
- The problem appears to be some internet URLs not resolving into IP addresses?
While other internet activities function normally. (other web sites, email, ICMP (Ping), video streaming,etc.)
Can you please check the Advanced Tab, Security Menu and see if there is an entry in the Block Sites table?
San_Tehnik
Hi,
thanks for your answer.
I checked the blocked sites and it's empty.
I'm not sure what the real problem is.
When I try to access the site, I get a message from the browser
hmm. We're having trouble finding that site.
If you entered the right address, you can:
Try again later
Check your network connection
Check that Firefox has permission to access the web (you might be connected but behind a firewall)
(This happens in all browsers)
- CrimpOnJul 09, 2023Guru - Experienced User
Just crazy.
- Connect using WiFi, web browsesr load the site.
- Connect using Ethernet, web browsers all cannot find the site.
On Windows, the WiFi adapter and Ethernet adapters have separate settings for how they determine DNS servers.
(using DHCP to be told which server to use - which is usually the gateway router {Orbi}) or
DNS servers defined by IP address.
Does it work the same way on Mac?
- San_TehnikJul 09, 2023Aspirant
That's it!
You are right, on mac os you can separately configure dns for wired connection and wifi. but I have the same dns configured
8.8.8.8
8.8.4.4
I check my DNS here - https://www.dnsleaktest.com- CrimpOnJul 09, 2023Guru - Experienced User
Since these DNS servers are defined on the Mac, the DNS requests pass directly through the Orbi router and are not processed by the Orbi DNS mechanism. I can think of nothing that would cause DNS requests to be handled differently because of how the computer is connected to the Orbi.
Just for an experiment, it might be worth changing the DNS to query more than Google. I, myself, use both Google and Cloudflare (1.1.1.1) DNS servers.
Is there anything unusual about this particular web site?
