scottmark271
Mar 18, 2025Tutor
Re: RBR850 Dropping Internet Connectivity
Hi there, Just wondering if anyone else is still getting these issues. I am struggling to be honest. My dropouts are completely random. Like two or three in one day and none for 3 months. I have...
- Apr 11, 2025
Glad you go it working.
You can add screen captured to any post by selecting the camera icon in the post editor. Or generate picture files and attach them to the post.Please mark your thread as solved so others will know. Be sure to save off a new back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
scottmark271
Apr 10, 2025Tutor
so here is the latest update.
Post attempting a full factory reset that did not go well and then going back to my stored config I noticed something that was very strange.
If I logged on to the network my ORBR (I.e. router) was showing as a device connected to my Satellite which I have seen before. I am thinking this might be a part of the problems I experienced!! The satellite was then not showing on the router and remember that I have ethernet backhaul
So what I ended up doing was turning the two satellites off an rebooting the router - it did its thing then paused and did it all again - so once I waited for this I then turned on the satellites one at a time - they too came on and did their thing - twice.... however the second time they gave me a very nice blue light show and now everything seems to be behaving much better than before. No dropouts to speak of (touch wood) and best of all as I walk through the house no issues swapping from one access point to the other (which used to take a while).
so I think that my base set up was wrong although the advice to get the right FW I think was the first step to getting this all sorted out.....
it is nice to be back counting onself as a Netgear Orbi fan again... And it's nice to have everything ticking along too.... thank you for all the advice along the way.... Should really figure out how to get a share screen option in the community because I think you would have solved my issues (and stupidity) much quicker that way - although I get the security and privacy issues so don't shout lol
have a great weekend!
Apr 11, 2025Guru - Experienced User
Enjoy. 📡
