HomeUserguy
Sep 19, 2022Aspirant
RBR850 Firmware V4.6.9.11 schedule broken
After upgrading to V4.6.9.11 the schedule I have for blocking site for the kids is off by like 3 hours. I have validated the NTP setting and the date /time. I have a rule to start at 20:59 (8:59pm) ...
Sep 19, 2022Guru - Experienced User
What time zone are you in?
Do you have Access Controls enabled or SPC?
Has a factory reset and set up from scratch been performed since last update?
HomeUserguy
Sep 20, 2022Aspirant
I know that is tech support 101 to reset things as I have over 20 years of IT and network exp 🙂
lets look at the following.
#1 100% working no issue before upgrade
#2 Firmware upgrade ---> still works but off by 3+ hours
#3 Time zone is set correct
#4 NTP is correct
#5 I am not resetting my router because it cant tell time 😛 and everything else works
#6 -5 eastern
To me there is a bug in the logic that is messing up the time validation (would be my assumption). It most likely is staying in GMT or another time and not honoring the time zone.
again, no issue before the upgrade..... Still works just off by a number of hours.
The problem just related to hours.... everything else works
