aebrahim
May 05, 2022Aspirant
Re: RBR850 not reachable after Firmware 4.6.8.2 upgrade attempt
Hi, I have the same problem as the original poster. After upgrading my RBR850 to 4.6.8.2, I can't get into the admin interface anymore. The network is still working fine. I've tried powering everythi...
aebrahim
I've tried telnet to ports 80, 443 of the router (192.168.1.1) and its refusing connections.
aebrahim
The firmware notes say that "Removes the remote management feature from the router web interface (if disabled at time of update) to improve router security."
I have a feeling that it's somehow disabled the web interface entirely in error. Any suggestions?
- jkk4_1998May 05, 2022Apprentice
I too have the exact same problem with my RBK852. Has anyone been able to fix this problem?
- aebrahimMay 05, 2022Aspirant
Finally I was able to solve this with a factory reset.
- FURRYe38May 05, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
