CrazyEddie
Jan 17, 2021Apprentice
RBR850 poor backhaul status
I've got an Orbi RBR850 router and two RBS850 satellites. The router is on our main floor. The satellite upstairs (directly above the router) shows "good" for backhaul status, and was just added today...
Jan 26, 2021Guru - Experienced User
Understand. However in some cases, wireless may not be a great option. Building materials and distance can effect ANY wifi router system. So reason being there NG offers and supports the wired connections as well. For those who can or wish to use it. And yes, we all know not everyone can have wired connections. :smileywink:
CrazyEddie
Jan 30, 2021Apprentice
I can't stand when someone asks me for help or advice and then doesn't keep me posted, so in that spirit, here's the latest:
- backhaul status on both satellites more often than not is now "Good"
- devices do not seem to be dropping from the mesh network, even the older iPhone my wife uses
- speeds vary by device and location, but top speed on the mesh seems to cap out at about ~5-600Mbps/35Mbps using the Ookla app, and ~750/43 using the Orbi app speedtest
- Perhaps most surprising to me is that the devices seem more likely to connect to the satelites on another floor (I assume closer as they are directly above or below) than the router on the same floor with just some drywall in between them. (At the moment, I have 11 devices on the network, and the only one connected to the RBR is the doorbell, which has a direct line of sight - apart from the front door that is between the two.)
Thanks again for the assistance!
- FURRYe38Jan 31, 2021Guru - Experienced User
Thank you for letting us know.
