Obie3
Aug 26, 2023Aspirant
RBR850 running slow
I have an Orbi RBR850 router with one satellite connected to a Netgear Nighthawk CM2000 cable modem. Primary RBR connected to modem with Cat 5E cable. There are multiple devices directly connected to...
Aug 30, 2023Guru - Experienced User
Can you give details on how the RBR was "defunct"? What do you mean by this?
Obie3 wrote:
Problem corrected. RBR850 router was defunct. Replaced with new mesh system. All speeds (LAN and WAN) now run at ISP service speed.
Obie3
Aug 30, 2023Aspirant
By defunct I mean that the router speed was degraded, no setting adjustments would correct it. Not related to my modem as I disconnected it and set it up on a similar but completely separate system with the same results. Not related to connected devices as all were disconnected except for one LAN desktop connection. At that point, I installed a new mesh system (router and satellite) and instantly had speeds within acceptable range of ISP service speed on all connected devices.
Whether the fault is due to age (3 years old) or internal component failure is inconsequence (BTW, all devices power including the router are connected through an APC XS 1500 backup UPS and power conditioner).
- FURRYe38Aug 30, 2023Guru - Experienced User
Thanks for the details. Keep an eye out for next FW update.
Good Luck.
