ottopaulsen
Nov 02, 2021Tutor
RBR850 still losing internet connection several times a week
All info on previously closed case. I am still loosing internet connection several times every week. The thing is that it ALWAYS helps to reboot the router, or even logging in and running Intern...
Nov 05, 2021Guru - Experienced User
Can try loading the config file and see, if problem continues, i'd try reset and do a test with out loading the backup from file.
ottopaulsen wrote:
Ok, thanks. Guess I have to try this.
I have 32 devices with fixed IP, based on mac address. Is there a way to export and import them, so I don't have to enter one by one through that tedious interface?
Otto
ottopaulsen
Nov 08, 2021Tutor
Now it is done, so let's wait and see.
I entered everything manually.
Please keep this open until I have tested at least a month or two.
