greazer
Dec 27, 2024Tutor
RBR850 turns pink/magenta every day or so.
I've successfully used my RBR850 router with 2 satellites for just over 4 years. However, for the past 6 months or so, I've been starting to lose internet somewhat randomly every day or two, sometime...
Dec 28, 2024Guru - Experienced User
Yes, Just make sure any IGMP and Green Ethernet protocols are disabled on that switch. I believe thats a managed switch since it has smart switch features and a log in management web page...I consider any switch having a web UI log in and management page a managed switch.
See if this still happens if the one switch you have in the middle...
K, Nieghbors maybe using ISP router so they may not be seeing this issue.
greazer
Dec 28, 2024Tutor
All good. I was able to ensure that IGMP and Green ethernet are disabled on the switch. We'll see what happens the next day or so.
Thanks so much for your help!
- FURRYe38Dec 28, 2024Guru - Experienced User
- greazerDec 30, 2024Tutor
Just an update after two days of having the switch in-between the ziply ONT and Orbi. So far, I haven't had a dropped connection (pink light). However, there have also been times where I've gone a week before that happens. So while I'm optimistic this had a positive effect, I'm not fully convinced it's a solution yet. 🙂
Would be nice to not have to require this setup though. I.e. if it is an incompatibility/firmware bug of some sort, would be great to eventually get a fix. But I digress... - FURRYe38Dec 30, 2024Guru - Experienced User
Lets let this run for a week or so and report back.
Ya there maybe some odd FW issue at the RBR and handling a direct connection with your specific ONT unit. Only other idea would be to try a different branded and model ONT. Not sure if your ISP has anything different.
- greazerDec 31, 2024Tutor
Ok no need for a week. It turned pink sometime last night. Here's what I did this morning.
1. Before doing anything, I plugged a laptop into the switch connected to the ONT. It was able to hit the internet just fine.
2. I removed that laptop from the switch.
3. I rebooted the orbi from my desktop PC.
4. The router went back to pink after going through its white-blinking phase.
5. I did step 3 again, just to make sure I wasn't crazy. I'm not. It went to pink again.
6. I then power cycled the router.
7. Again, blinking-white, then pink.
8. I did step 6 again. Same result.
9. I removed the switch and plugged the router directly back into the ONT. Then power cycled the router.
10. Everything is back up and working.
So... ? I have my own theories, but curious what anybody else thinks, since I'm no expert here.
- FURRYe38Jan 01, 2025Guru - Experienced User
Dang.
And this is with v.21 FW loaded?
And a factory reset on the entire system was performed?
Swapped LAN cable between the ONT and RBR? CAT6A STP is recommended.
Ya, running out of ideas here. Can only think maybe the RBR is going bad? One other way to test this would be to test the RBR out a different location with a entirely different ONT or cable modem like at a friends or families place to see if the problem follows.
Or see if you can find another RBR850 to test with. Maybe like Amazon or shopgoodwill.
- greazerJan 02, 2025Tutor
- Yes, v.21 FW is loaded on the router and 2 satellites.
- No, I haven't performed a factory reset. Been avoiding it as I have a bunch of devices that have static IPs. Though can I backup and restore?
- I have tried multiple cables, several new and CAT6. I haven't check whether they were "CAT6A STP", but somehow I doubt that will help this problem.
Thanks for all your help, I truly appreciate it! But yeah, I'm thinking that it may be time for an upgrade anyway. But maybe I can find a cheap replacement as you point out.
- FURRYe38Jan 02, 2025Guru - Experienced User
Ya if you downgraded from v.31 to v.21, a FR was required after v.21 was applied to the system and setup from scratch.
If you have a v.21 backup file, then ya, you could apply this to be back up and running in minutes.
