GregS_from_MI
Sep 11, 2025Apprentice
RBR860 intermittent disconnects
I have had this Router plus 1 satellite since March 2023. It is connected to Hitron EN2251 modem from Spectrum. The router and modem are plugged directly into the wall plug. Both sit in the open and ...
GregS_from_MI
Sep 12, 2025Apprentice
Yes my ISP supports IPv6.
Here is a screenshot of the LAN cable, sorry I'm not a wire geek, let me know.
I'll update the router and satellite later.
Sep 12, 2025Guru - Experienced User
Ok, if you noticed odd issues on the IPv6 level, disable IPv6 on the RBR. Others reporting having problems with IPv6 on this version of FW>
Thats UTP cable then.
K.
Also check the Uptime seen on the WAN port on the RBRs web page under Advanced Tab/Show Stats and compare this to the system uptime seen on the router IP address/debug.htm page.
