Pardman
Nov 17, 2022Tutor
RBRE960 VLAN
I have the following setup: - One RBRE960 Router - Three RBSE960 Satellites - Each of the devices has been upgraded to the latest firmware - Xfinity broadband I am interested in running a cry...
Nov 17, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Pardman
Nov 17, 2022Tutor
Firmware is 6.3.7.5 for both router and satellites
Comcast Modem (cable): Model XB6-T. It is modem they provide. It's actually a router/modem combo, but I have it running in bridge mode.
- FURRYe38Nov 17, 2022Guru - Experienced User
How do you have the VLAN configured on the RBR?
After applying the VLAN configuration, try a reboot or power OFF of the RBR AND ISP modem for 30 seconds then back ON with the modem first then RBR.
- PardmanNov 17, 2022Tutor
VLAN configuration attached (see pic). FLUX is the VLAN I am trying to setup. Note, the IOT VLAN seems to be working properly (I believe it is all wireless)
I restarted Xfinity modem and RBRE960 and still no internet connection.
I would note that my internet connection worked great until I added the FLUX vlan, and then it stopped working, and I cannot figure out the reason
