Pardman
Nov 17, 2022Tutor
RBRE960 VLAN
I have the following setup: - One RBRE960 Router - Three RBSE960 Satellites - Each of the devices has been upgraded to the latest firmware - Xfinity broadband I am interested in running a cry...
Pardman
Nov 17, 2022Tutor
VLAN configuration attached (see pic). FLUX is the VLAN I am trying to setup. Note, the IOT VLAN seems to be working properly (I believe it is all wireless)
I restarted Xfinity modem and RBRE960 and still no internet connection.
Pardman
Nov 17, 2022Tutor
I would note that my internet connection worked great until I added the FLUX vlan, and then it stopped working, and I cannot figure out the reason
- PardmanNov 17, 2022Tutor
An additional point, is that I have assigned the FLUX VLAN to "port 4" which I assume to be the LAN port on the back of the router farthest away from the WAN port (or the port farthest to the right). The port numbers are not labeled on the back of my router, so I'm not 100% sure this is a correct assumption.
- KevinLiTNov 18, 2022NETGEAR Moderator
Hello Pardman ,
Thank you for your post!
I understand that once you added a new VLAN to your network you were not able to access the internet. The ports on the back of your Orbi are 1-4 from left to right. Your assumption is correct.
Please try setting your VLAN priority to 0 for your new VLAN then verify the network connectivity.
Best,
Kevin
Community Team
