Contz
Nov 24, 2022Tutor
RBRE960B Just one Ethernet port acts weird
Hi there, I've this system from Feb now. It works great. I've a Xbox Series X and a Playstation 5 attached to the main base. Just one ethernet port seems to act strange. Both with Ps5 and Xbox ...
Nov 25, 2022Guru - Experienced User
Funny, new FW works for me and my 2.5Gb ports.
2.5Ghz or 2.5Gb?
Again, to get good use out of 2.5Gb ports and make sure all works, CAT6A STP cables are recommended.
One can connect LAN switches up to the RBR for additional ports when needed.
Also a factory reset and setup from scratch would be needed if you see problems.
Good Luck.
Contz
Nov 26, 2022Tutor
Listen, why the fault should be on my side?
When there is a buggy firmware, works for you on PlayStation Plus/store and Xbox Live?
Otherwise as said it works for me too.
- FURRYe38Nov 26, 2022Guru - Experienced User
Well I set my 9 series up yesterday in AP mode for my needs with v6.3.7.5 loaded back in October.
I connected my xbox series X to the 2.5Gb port on the RBR. Left the RBS wireless connected.
I gamed for 4 hours last night with out a hitch on MW2 2022.- ContzNov 26, 2022Tutor
Don't know what to say.
Lucky you.
Now it's not working again on my side since the firmware auto updated.
- ContzDec 04, 2022Tutor
still same problem
the router auto updates itself anyways
ive changed cables, I ve connected my new LG C2 tv and even with that it cannot access its own apps or view netflix content or any other ott.
